SpoonsbySven
Hi Folks,
Recently bought a second hand Kity419 table saw, and have a few questions. I've spent a fair bit of time today Googling, and searching this forum, but haven't managed so far to find definitive answers to the following questions. Any contributions gratefully received.
1. Blade tilt adjustment.
I saw a few comments before buying warning of a slightly Mickey Mouse tilt adjustment mechanism, but they only made sense once I got the saw home and had a proper look (duh, I know, but there was a lot to look at...). Mine is mashed, and I'm reluctant to replace with another (expensive and equally rubbish) plastic one. I've seen reference to a brass replacement and also found Mr Ed's thread where 9fingers and Andy Pullen came to the conclusion that a 12 tooth, 28mm dia, 2 Module gear (like Part G2-12 from http://www.hpcgears.com/pdf_c33/23.50-23.55.pdf HPC gears) would do the trick.
a. Has anyone actually done a modification like this? If so, I would be really grateful for pictures/tips, particularly on how to join the gear to the rest of the handle!
b. There are a few mentions of a brass toothed replacement. Stuartpaul said that NMA have produced one (for roughly £65??!). Has anyone successfully obtained one? I will try contacting NMA direct by phone or pm-ing the chap on here.
c. Somewhere on this site, I found a thread by someone who had recently sold a 419 (and therefore didn't have any pictures) who had discarded the silly plastic gear and used some threaded rod and welded on brackets to make something like the Axminster TS200's tilt adjustment. I found it a bit hard to follow, and now can't find it again. Has anyone tried something similar?
2. Fence lock
The fence locking screw on mine has marked the fence rail quite badly, and I have some concerns that it might eventually affect accuracy. The central bolt has pushed through the end piece (looks a bit like the end of a G-clamp screw), and is marking the ali fence rail.
My first thought is to fix a thin strip of metal between the end of the bolt and the fence to protect the fence, or possibly just fill the middle of the hole with epoxy so that there's something between the bolt end and fence rail.
Does this sound familiar to anyone, and any thoughts as to how to deal with it?
3. Hole for zero clearance insert
I'd like to make a Zero Clearance Insert. The opening isn't exactly rectangular, and it occurs to me that it would be easier to file the Ali table rectangular than faff with making all future inserts an odd shape. The other advantage would be that this would leave more material directly in front of the blade (joining the left and right "halves" together), making it stronger.
Any tips from anyone who's made a 0CI for a 419?
Thanks to Bean, sawdust-jonny and knappers and others for excellent coverage of dust extraction!
Thanks all. Have been enjoying the informative banter on the site immensely, and hope to be able to contribute something useful myself at some point!
Sven
2. Fence lock
Sven
