I work in a 20ft x 10 ft concrete sectional building in the garden. The walls are lined inside with 2" celotex and 18mm chipboard. The roof is single skin cement fibre corrugated sheets. When the suns out, by mid day the inside face of the roof is red hot and the inside of the building is around 30 degrees and we aint even in summer yet! The walls are cool to the touch a) due to sun not shining on them and b) they are insulated and lined anyway.
So my overheating problem stems from the roof. I have experimented with putting an offcut of 30mm celotex across the roof sheet supports and after a couple of hours the heat from the roof has worked its way to the inside face (warm to touch) . Any ideas what I can do to stop the heat coming through the roof? I can only think line with thicker celotex but how thick do I need to go to stop the heat. U values for roofs should be around 0.15 which means I think around 150mm celotex required to stop heat passing out. So does stopping heat coming in work in reverse?! ie I need 150mm lining inside the roof?
any ideas appreciated apart from fans and air con
