Kapex 120
SteveF
16 Sep 2013
Maidstone
does anyone own this?
I am building workbench and need to confirm the gap I need to leave to fit this in
spec says
713 x 500 x 470mm
does this require a 713 or 500 "space" to sit in?
I am guessing that width is the 713 just want to confirm before i make provisions
it is out of stock so cant go and measure one
Steve
I've got one, where is it out of stock? N&B usually have stock and their prices are probably the lowest in the UK.
I can measure mine in the morning if you still want the info then?
in the morning would be great please
I have it on back order, just trying to get the rest built so need the gap required to drop into bench
I can then go to outlet and get best cut from mr mdf
saves me getting track saw out as can use cutting service for this one
if it is 713 ...i will go with 2440 cut to 714 x 3 leaving a "scrap" of 298 -kerf (gives me a 12" shelf for other uses)
so will give me 1220 x 714 x 2 of benches plus a 714 for the saw which i can get ripped to 714 x 714
this will give me a 3154 work length..which should let me have a decent work area
thanks Ed
Steve
Yep, sorry for the delay.
Width of Kapex 62cm
From back of Kapex to front of fence 37.5cm
Full depth of Kapex to edge of front lever 80cm
Width with Crown Stops wings fitted 84cm
Hope this helps, Eddie.
