Just a quicky
knappers
19 Apr 2010
Leicester
I had been getting fed up of loose toilet rolls floating around in our downstairs loo, so decided to pull out some scrap oak and make a toilet roll holder.
First I turned the bits for a sprung spindle.
Assembled spindle
Finished and mounted to wall using screws in routed keyhole slots in rear.
Si.
We've got a bog-standard one but that looks classy, well done.
What stops the spindle coming apart when you change the roll?
Regards Keith
If you look at the first pic, one core piece has a stepped end, that sits inside a stepped hole. The other straight one is glued in place, meaning just one end is sprung, but is stopped by the step.
Si
