I'm planning to lay plywood as the flooring for our downstairs entrance/hallway/kitchen and then eventually continue this into the Lounge.
Presently its some boggo B&Q laminate from the Lounge to Hallway, and then different laminate in the kitchen.
The "plan" so to speak, is to make an accurate drawring of the hallway and kitchen, then with the relevant quantity of ply sheet, cut it out and "drop" as big a piece as possible. The small problem is that the hallway is a shade under 3M long and circa 1.6M wide, this would lead even an oversize sheet to need 100mm adding to the edge, no biggie as that side will have a unit over most of the join anyway.
How would you butt join plywood? (looking at 15-18mm Hardwood or puppy or WISA ply) Would glue and biscuits do the job? will the biscuits swell up and make a mess? Would this be ideal for pocket holes?
