Duparcq":1bu8f4fd said:
Bob,
The assembly table is a good idea
Could you tell me:
1. The length and width of the runner assembly that supports the sliding table
2. How easy it is to manoeuvre the axi on the wheel base
3. Which blade you would recommend
4. The length of the long fence that fits onto the sliding table
5. Have you had any issues re the accuracy of the sliding table
Regards
Brian
Blimey Brian...I had to go get a tape measure to answer your questions...you know...that involved moving from the chair where my tea was and everything
Here we go...even took a few snaps for you.
Runner assembly is 6 foot dead by 8 inch off the side of the saw. Its on Bristol lever locked positioners so you can move its starting point such that the sliding table can be brought all the way in front of the blade. This is deliberate so you can fit a full 4 foot sheet good in front of the blade. My usual position is to have the runner out the back of the table so I can easily manoeuvre myself when standing in front of the saw (such that the table extends out the back of the saw).
Its not too bad to move around on the base. That process is made harder if (as I do) you have the right hand table extension because its supported by a steel leg which is of course outside the wheel base. You need to just pop this up a couple of inches before moving it or it snags on the ground. You could make a tiny little dolly to make this mobile if you were feeling particularly anal one Sunday morning!
I have a general ripping blade but the one I use most often is an 80 tooth fine cut blade because the finish is awesome. For very important cuts (ie those which will be jointed with real wood as opposed to sheet goods) I always over cut by about 0.5mm and plane back to true so there are no blade scoring marks etc that might affect the joint.
Long mitre fence....1060mm extending to 1800mm.
The sliding table is fiddly to setup initially because you're competing with distance from side of table with distance from top of table. Each time you adjust one it throws the other out a fraction. So, trial and error a bit. What really helps is a good magnetic dial gauge so you're dealing with definites. Like all precision setups, it takes a while but it's eminently do-able and once set I haven't needed to change it.
Heres a few snaps showing the sliding table assembly and that supporting pillar on the RH table extension...and the wheel base which I remember now I bought from Axy at the same time.
My experience, its a very solid machine with large capacities. I had the TS200 before and that's a toy compared to this.t
