The allen key to secure the blade has rounded off, instead of just buying a like for like replacement can you upgrade it, so making blade changes is a bit easier as well
I still havent managed/had time to fix it, and havent used my saw since, the best ive found is http://www.wdsltd.co.uk/product/3606/cl ... y-wds-8189 but am not sure it will work with the limited space, has anyone tried one or has anyone got any better ideas because I cant used my saw till ive fixed it, ive had a search through past posts but I cant find anything, any help would be much appreciated
Mark, I'm pretty sure I had this on the bottom clamp of my Jet. Obviously you need to leave the side panel off but that's no problem. If you want it, PM me your address and I'll stick it in the post.
