I'm building the kids a playhouse and I want to make it as useable as possible all year round so it's going to be insulated and eventually have power running to it.
The structure is 3.6m x 2.4m so about the size of a decent shed and I'm going to bed nine concrete blocks into the ground and build two brick courses on top to keep the deck off the ground. I'm using 150x47mm joists with an 18mm T&G MR chipboard floor, insulation between the joists and then the plan was to clad the underside with 11mm OSB.
Does that sound OK?
I've only ever built off concrete before not a floating deck so any advice would be appreciated.
Does that sound OK?
