RogerS
From our surveyors' report...
The incoming main appears not to contain an earth back to the grid; it is recommended that the incoming cable is altered to include an earth, so the electrical system can be earth-bonded and fitted with modern circuit-breakers for safety.
The incoming main passes an old main distribution box, with pull-fuses. It is recommended that the fuse boxes are upgraded to RCD boards. Ring mains and local wiring are in modern plastic-sheathed cabling
The incoming mains is underground. The property itself is out in the sticks. So is it a simple question of an electrician connecting an earth spike to the incoming neutral? That's what we currently have on our current house - fed from a transformer up a pole.
