I have been helping my son fit an Ikea kitchen.
The original plan included a 600mm wide integrated dishwasher. We knew that space on the run of cupboards including the dishwasher would be tight and depended on how much we could regain from removing a box around a 110mm drain pipe in the corner. As it turned out we were short by over 50mm. So plan B was to use a 450mm dishwasher.
We have now almost completed the kitchen and all was well until my son went back to Ikea to swap the 600mm door for a 450mm one. He was told “we only do a 450mm door in stainless steel, you will have to use a 500mm door “.
Had we known that before we could have left a 500mm space but that is now impossible without redoing half of the kitchen.
The door is foil (vinyl?) wrapped Abstrakt glossy black (it’s plain with slightly rounded edges).
Some of the options we have considered to get around this problem are:
1) Try and get a custom door made – a number of companies offer this service but I suspect I’d struggle to match the colour exactly– or am I wrong?
2) Cut down an IKea 500mm door and somehow making the cut edge blend in the best we can. At least the dishwasher is in a run of units so the edge is not fully exposed.
As I am not sure that painting the edge would be very successful, I thought of using a router to machine the door to 450mm by forming a groove from the back, removing all of the MDF but leaving the foil edge intact and wrap it around the newly cut door edge afterwards, perhaps with a narrow strip of wood inserted to give the required edge radius.
I have a few questions on this and any comments would be appreciated:
Is there is sufficient foil thickness to give it a chance of working?
Has anyone tried this before and if so what was the outcome?
How does foil react to being ‘cold formed’?
Would some gentle heat help (hairdryer)?
What is the best glue to use?
As there is 50mm ‘spare’ foil it could be wrapped around the back of the door as well, thereby making it less likely to become unglued.
