Tony Spear
If you already had a variable speed belt sander and a (very) old 1/3 sheet orbital sander, which vibrates like hell and probably won't last much longer and had a very tight budget (say £60 - £100) what would you go for at this stage: ROS, Palm or Delta?
Main use would be for finishing things like door panels (raised and/or rebated), stiles and rails of said doors, book case frames and shelves etc.
Which is the most important feature for a decent finish, orbit size or speed?
I should say that the belt sander can be inverted and can be fitted with a sanding frame to avoid dig in when used conventionally on panels.
Edit: I should also point out that I should be able to get another sander at similar cost wthin the next 2 to 3 months, but don't want to wait that long and buy a more expensive piece of kit unless there are good solid reasons to wait.
And also that I am very much a hobbyist and don't do loads and loads of woodwork.
