Identifying replacement corrugated sheet roofing
E-wan
5 May 2018
Leeds
Hi
I'm looking for a new clear corrugated roofing panel to match the one in my garage.
The corrugated sections are flat on the top and bottom, about 35 mm deep with approximately 250 millimetres between the centre of each corrugation .
It's made of a translucent fibreglass plastic.
They're also available in fairly long sections as I remember when we had the roof done on the garage they used a single sheet and had to cut a bit of the end.
Any help on identifying what these are called and where to find a replacement near Leeds would be greatly appreciated.
It's the translucent sheeting I am after but the matching metal sheeting the roof is made from has a fleece lining to help prevent condensation build up dripping if that helps with identifying the brand.
Photographs attached
Ewan
