I do not like titebond
Grahamshed
14 Apr 2012
Oxfordish
I have always used evostick resin w but have just tried a bottle of Titebond. It is so watery, runs all over the place.
Messy stuff
Has anyone used D4 ? is that any better ?
titebond is excellent, has your bottle separated?
thinking about it, its quite runny but you really only need the lightest smearing!
adidat
adidat
I will try that but the bottle says to use a heavy spread. I wouldn't say my use was 'heavy'. I used the same amount as I would resin w but it was running off the wood while I was assembling some biscuit joints and really splurged out when I clamped them :)
do some tests maybe but i seem to remember a small amount working very well, also means less glue to clean off your clamps :lol:
adidat
Rule of thumb - Glue oozing out when you cramp up means far too much glue used - Just a few beads of glue appearing on the joint line is ok.
regarding Titebond - I use it all the time with excellent results and have never had a glue failure.
Oh and remember to put a post it note over any glued joint to prevent it coming in contact with the steel of a clamp - otherwise you end up with those awful purple stains.
You could just use scrap paper but I find post it notes stay in place!
I don't like it either, the dark glueline from TB3 has caused me major problems on a couple of pale timber jobs. I've gone back to good old Evostik Resin W, which dries clear and is strong as anything. No more Titebond for me.
phil.p":3498168n said:
D4 is totally waterproof, D3 isn't. Everbuild D4 is a bit thin, but you get used to it. It's brilliant stuff. Resin W is good, but expensive for what it is.
Everbuild D4 is excellent stuff...I pay less than a fiver a litre - Rob
I use titebond 3 and it does ouze out on my strip projects but I wipe it off with a wet cloth immediately and never seem to be troubled. ( If any laying around after set I clean up with a chisel within 6 hours and it removes easily.
Bit of a noob here but is No More Nails interior rubbish then? Or is Titebond etc more for fine work?
I make toy wooden castles/ forts and use NMN for that as I overpaint (usually) and its great? Its always the wood that gives way before the actual glue does.
Yeah go on, rip me to shreds :)
I've used titebond original for bookmatched centre joints in maple, with invisible glue lines - IMO if you're getting a dark line you need to prep your joints better. No experience with II or III, as they're not recommended for what I do (mostly musical instrument work).
TB3 is light brown when wet and dries to leave a darkish brown glueline, thanks for the tip about preparing the joints better though.
