LancsRick
Happy Saturday all!
I've nearly finished getting my startrite 175 up and running and wanted to check something...
It currently has the standard 1.1kw motor fitted, with new belts. I've set the belt tension to allow a quarter turn between finger and thumb with firm pressure which I understand is the right way to go - it has eliminated any belt slip under load at least. The bearings seem ok - both motor and blade spin freely without belts and give no noise or abrasive feeling. No slop in anything.
Having run the saw for ten minutes continuously or so I decided to check all was still well, and it was, but the pulleys (both) were definitely heated up. I could hold my hand against them but would say "hot" rather than "lukewarm".
No, not having had a proper saw before, is this normal or a point of concern? I will be upgrading the motor soon regardless, but wanted to check I wasn't going to transfer an issue to the new one if this was indicative of a problem I should solve first.
Cheers!
Cheers!
