Peter G Denmark
Hello.
Can anyone recommend some cheap-ish sharpening stones, and recommend which grits to get? I live in Sweden, so it has to be an online store, that ships to the rest of the EU.
I have a 2 sided Norton India oil stone (think it's 250 and 600 grit), a second hand Scheppach Tiger 2000 wetstone grinder that i paid £20 for, and "green soap" honing compound. Also i recently went to a company that sells granite counter tops, and found a piece that was 40x400x450mm, which is flat.
The problem i have with these things are:
- The wetgrinder's wheel doesn't run 100% true, and a truing tool costs £50 (Tormek). I've tried to true it up with a diamond dressing tool with some succes, but it is not spot on. Even if i buy the truing tool, i still think the step from the stone to the lapping wheel is a little big, in that it looks like i'm kind of polishing scratch marks, and therefore not leaving a super fine edge.
- The India stone is a little small when it comes to sharpening jointer plane blades, and it's pretty coarse.
- Sandpaper on the granite wears out really fast, and the 3M lapping film is very expensive, especially when i have to pay shipping.
I can sharpen my chisels and plane irons to a pretty decent edge with these tools, but they just don't produce the results i know you can get.
So - what should i get. I've been thinking about the EZE-LAP diamond stones (http://fine-tools.com/ezelap-diasharpener.html) in a 250, 600 and 1200 grit, and then stropping on a piece of mdf with the green soap or Autosol. That would be about £150 for the lot - still a little expensive, but WAAAAY cheaper than the water stone route. What do you think?
Also - i've recently gotten 8 wooden handplanes, and i need to flatten the back of the blades. Has anybody used and beltsander for this? I'm SICK of spending 1 hour on every blade, so would love the power tool thing, for the initial flattening. Of course i would be carefull not to overheat (dipping in water etc'), but in my view the back of the blade is a lot less likely to overheat, since you're not grinding on a small area, like when you grind on a bevel. Or do you have any other suggestions?
BTW - a magnetic base, like the ones on dial calipers are great at holding plane blades when flattening the back. At £10 from axminster it was a steal when considering how much fingerpain it has saved me, and the pressure is distributed very evenly
Thanks - and foregive my english. It's not my first language.
