hollow bed bars
barryb
New member
4 Mar 2004
hampshire uk
Hi to all
I have a question that i would like some help with my lathe is a dml 24 with hollow bed bars and i would like to know if anyone has had any luck with using sand or cement in the bars to add weight and deaden any vibration.
cheers be happy
barryb
Bean
12 Jan 2004
scouting about
barryb
I have not had any experience with this, but then I do not turn wood. I know that some hollow aliminium sections are foam filled to increase stiffness. It may be another aveenue to pursue although it would not add weight.
Bean
woodshavings
20 Mar 2003
Alton, Hampshire
Hi Barry,
my previous lathe had a hollow centre tube . I found the greatest improvement was ensuring the lathe was firmly bolted to its stand and then fitting a sand box to the full width of the stand. This made is very solid and reduced vibration significantly.
HTH
Cutting Crew
5 Sep 2003
Chesterfield, Derbyshire
Hi Barry,
All the Record lathes I have in the school are the ones with solid bars but I also have one of Hegners 200DBXL's, this uses large hollow box section steel for the bed and although I haven't done it I know of turners who have filled these sections with oil damped sand and found improved results.
Filling any area that adds weight should help, bench, stand etc. Having said that, I've found that over the years there is no substitute for lathes using heavily cast parts. I have a new Powermatic from the US and this weighs in at over 700lbs and is a dream to use.
Hope this helps.
Regards....Mike Swain RPT
A
Anonymous
Guest
Hi Barry,
I saw a lathe of the same type advertised for sale second-hand. The advert mentioned that the bars had been replaced with solid steel rods.
Having bought solid steel rod in the past, I'll bet you could get hold of some for less than £10 to replace what you've got from your local metal stock-holders. Less messing and more solid than filling tubes perhaps?
Cheers,
Lee
barryb
New member
4 Mar 2004
hampshire uk
Hi everyone thanks for the replys .
I have had a think and I am going to give sand a try cause I'm a bit tight and i have some sand if it don't work I'll take a crow bar to to the wallet
cheers all Barryb
