HMS260 Cast Iron Table
Newbie_Neil
27 Jul 2003
Nottingham, England
I have removed the content, as it has now lost all sense, since the heading of the thread was changed.
Please note the replies below pertain only to the final point in my post which relates to a genuine query I raised on the D&M site.
Neil
A
Anonymous
Guest
While not being responsible for the info put out by dealers on their website, i am sure that they meant to say 1/10th of a mm.Will speak to D&M and hopeflly they will pu it right.
MENATNMA
Aragorn
6 Feb 2004
East Sussex
This is actually refering to the thicknesser isn't it? The height adjustment wheel is graduated to 1/10mm, but of course the rise and fall is continuous, so the accuracy is "infinite".
The blurb on the website is misleading (even if they typed it properly!) since the surface planer does not necessarily plane down to 1/10mm accuracy in terms of flatness. Unless the specs are different for the cast top (which I suspect they must be) Scheppach work to tolerances of 0.2mm (1/5mm) as I found out to my cost!
menatnma
16 Sep 2003
Brighouse
Have spoken to D&M and the advert is wrong, they will put it right asap and we look forward to other errors being pointed out.
Adam
10 Sep 2003
UK
Too late Neil, I'm now waiting for delivery. My order is placed :shock: .
Adam :D
Adam
10 Sep 2003
UK
To be honest, your title is a little unfair - and you might start a rumour!
Newbie_Neil
27 Jul 2003
Nottingham, England
Menatnma
The title of my first post was purely designed to seek the attention of Adam, as I was thinking of the P/T and Adam fitting it into his shed. I'm just surprised that you thought anyone might believe that part of my post.
I had posted the link to the D&M site purely as I thought Adam might be interested prior to his own P/T being delivered. Then when I read the sales blurb I couldn't actually believe what I was reading and I assumed I had made a mistake.
I was genuinely querying why it referred to a thicknessing tolerance of 10mm. I even referred to the fact that I must have misunderstood what I was reading. You have now identified that it was an error by D&M.
Neil
menatnma
16 Sep 2003
Brighouse
ta neil, no offence taken and it was understood in the right context, just the title was potentially off putting...
Menatnma
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi menatmna
I must have been having a bad day yesterday, as I really couldn't see what the problem was and I certainly didn't want to harm your product. I'm sorry if it caused you any embarrassment.
Perhaps you could clear up the question of the tolerance that the P/T is manufactured to. Is it now .1mm (point one of a mm) or still .2mm (point two of a mm)?
Neil
Bean
12 Jan 2004
scouting about
Neil
It depends on how the tolerance is written or the symbols used upon the drawing. In gerneral tolerances used for flatness are shown about a centreline ie 0.1 mm about a centreline is actually 0.2mm from peak to trough. You need to be careful and relate to the exact statement or preferably the drawing.
Bean
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Bean
Thank you for your reply, but I had phrased my question incorrectly. It should have been "what is the accuracy in terms of flatness of the thickness planer".
The D&M site, when describing the new HMS260, says: -
"Smooth, large-area work-pieces that can be joined to form a single, completely flat part with 1/10mm accuracy – this is the goal of surface planing." (my bold and italics)
This, I believe, is a 100% improvement over the previous machine. In which case, well done Scheppach.
Will nma please confirm this?
Neil
Aragorn
6 Feb 2004
East Sussex
Neil
Look at my post above about 1/10th accuracy.
I'm pretty sure this refers to the graduations on the handwheel.
Adam
10 Sep 2003
UK
My impression also is that any planer thicknesser that operates with threaded handwheels for raising and lowered effectively has "infinate" accuracy. More likely if you are having difficulty getting very fine adjustment, that the threads are caked full of dust I think.
Adam
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Aragorn
Aragorn":1jc65z2k said:
Neil Look at my post above about 1/10th accuracy. I'm pretty sure this refers to the graduations on the handwheel.
Thanks Aragorn, it's just that my last post was a direct quote from D&M and to me it seems that it is talking about flatness not graduations.
I could be totally wrong, of course. It has been known before. :oops:
Neil
Bean
12 Jan 2004
scouting about
With a threaded adjuster a PT effectively has "infinate" accuracy upon adjustment, but only if you eradicate backlash from the system. Backlash being the gap inbetween the threads in the adjuster.
Bean
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi all
D&M are obviously hell bent on confusing me.
Quote 1 "Smooth, large-area work-pieces that can be joined to form a single, completely flat part with 1¼10mm accuracy – this is the goal of surface planing."
Quote 2 "Smooth, large-area work-pieces that can be joined to form a single, completely flat part with 1/10mm accuracy – this is the goal of surface planing."
Both were on the D&M web site today. :roll:
Neil
Alf
22 Oct 2003
Up the proverbial creek
Tsk tsk. Someone doesn't feel the need to proofread then... :roll:
Cheers, Alf
Qualified proofreader (but please don't feel the need to point out my mistakes as a consequence of this info, it's been a long time since I did any. :p )
Pete W
31 Jan 2004
London
I assume it's a problem with embedding fractions in html. The forward slash is obviously difficult to type in directly since it's part of the internet addressing scheme so I guess they're using special characters and getting them wrong.
Dunno why they wouldn't just use a decimal - 0.1mm) instead; more accurate and easier!
Adam
10 Sep 2003
UK
At the end of the day - it doesn't really matter. No matter what distributors have on their website, most people have selected their machine long before that.
Dave at Homewood said he still hasn't recieved my order in from NMA, so lets hope it arrives tomorrow. With a bit of luck he'll be able to deliver it thie weekend.
Adam
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Adam
Jet have just received the stock of their jointer. :wink:
Neil
