Hi Phil,
I'm far, far from being an expert - DaveR is ours. If it's any consolation I was floundering around for ages with SU before I started to get anywhere.
My problem is I never read the instructions on the tin, just launch into it assuming I'll get the hang of it straight away.
You've got the idea by now of zoom extents I presume. As to your simple chest of drawers, I'll give you a brief idea of how I'd approach it:
I didn't really get anywhere with SU until I started 'assembling' the piece of furniture on the computer screen, just as I'd do with the real thing in the workshop. In my way of drawing this involves 'grouping' components as you draw them.
Back to your simple chest of drawers: lets assume you're going to make these with a sheet material carcass. First draw a side in outline as you mentioned, drag the mouse cursor round it to select it and right click, select 'group'. Whilst it is still selected right click again and select 'edit group' you will then be able to use the push/pull tool to pull it out to say 18mm. You then have one side of the carcass sitting there in front of you, next - control+move (gives you copy)and select an end of group marker on this side, drag this side over to the right and release ( it doesn't matter where - just in the right direction and plane) - type in the width of the chest of the chest in the dialogue box. You now have 2 sides the right distance apart.
Base:Next I would go back to the left side and draw a small rectangle locked onto it's bottom inside leading corner, again any size will do - just the right sort of shape in the right direction. Back to the dialogue box, type in the thickness of the base(18mm) and the depth of the carcass. Group this shape! Then 'Edit group' and type in the internal width of the chest. Hey presto - you have a 3 sided cabinet!
All you have to do now is copy the base to use as the top and or dividers.
Next Drawers: Measure up your openings, put in some central dividers if you want smaller drawers. Pan the main drawing across the page a bit to give yourself some free screen space. Draw a drawer front and push pull to get the required thickness. Yo then need to 'orbit' the drawing to put drawer sides on it, again put a rectangle on, group it and pull it out to the required length. You can then copy this one to the other side. The back you can manage by now. Orbit the drawer to look at it's base.....draw a square on the internal corners, and push this in by say 12mm, then having 'clicked off' push it in again by 6mm. You now have a 6mm drawer base set in 6mm.
Group the drawer as one piece! You can then move or copy the drawer by selecting an outside corner and taking it over to the carcass assembly and selecting a corresponding corner of a drawer opening. I tend to then pull at least one drawer open by about 50mm just to ....well, just because I do.
Wooden turned knobs are easy too......but that's another day.
hmmmm......hope some of that made sense, it did when I was thinking it through.
Chris.
