Matt_S
I posted a wanted for a benchtop planer/thicknesser... but ended up getting something a little larger!
This was taken when I first got it... hence no outfeed table. I've spent a day setting up and adjusting and having a go with it but do have a couple of questions/problems. Both tables need some adjustment as they both dip towards the cutting block. The infeed tables move up and down on these bars;
So the only way I can see to adjust is to shim. I seem to remember someone used coke can as a shim as it's thin, seems a good idea unless anyone has a better idea?
I've also not been able to get the hood on I know it's going to be simple! I presume that on this model I should be able to seeing it round from planer to thicknessing mode? Can someone confirm?
Finally, the worst thing I've found. It seems to have had something dropped on the infeed table and so one corner is WELL off the other three. Short of a new table I thought it could be built up with epoxy resin? With a straight edge and feelers is it ambitious to think I can get it flat enough for hobby use myself rather than having it milled?
