I'm getting towards the finishing stages of a small handmade table project for my woodwork evening course. The wood used is just cheap softwood from the local timber yard, having seen the store room in the back of the collage I can see they are simply buying 6x3 timbers and ripping them to suit, so I would guess it is pine.
I'm at the stage where I have only the top surface section to sand down, and each piece has been sanding from 40-240 grit progressively. I intended to give it as a gift and so don't want to leave the wood bare as it wouldn't last too long. Rather than splashing on paint I would like to get a good finish and oiling seems a better option than varnish. After abit of reading I think Danish oil could be my best option but any better oil suggestions would be welcome?
So my main issue here is that currently the table is still in pieces and ready to glue up, but should I oil all the parts first and then glue up or oil up a fully made table?
My other issue is tips on how to fix a mistake on my part. The brace for the legs has been made with two pieces with a halved joint, initially I was lucky and this fitted perfectly first time, however in a sanding trance I accidently sanded down the sections that overlap on both pieces. Now I have a joint that only just makes contact and is far from tight. Any tips on how I can bulk it out a little so as to ensure a snug fit once more? There is around a 1.5mm gap now split between either side of the joint.
