kinsella
Colleagues
I have a Scheppach rab t 13x radial arm drill press for a good few years now, my problem is i cannot for the life of me get the arbor or chuck of our the shaft. Normally on drill presses you get the slot (key hole) for the key to strike out the arbor. This model has no slot. Another way on other models would be to put a long bar down the shaft to strike it out from the top. You guessed it, this model doesnt allow that without total dismantling, or when i done it last the top was solid.
i've used vise grips, i've strapped wood to it. Save me destroying the existing chuck, i'm at a loss of how to get the thing out. Any ideas?? save brute force and ignorance? (which i have in abundance)
Some suggestions put to me so far, use a blow torch to heat up the shank. But i suggest that will be extremely distructive too.
PS. its my own fault, it kept falling out at the wrong time and i gave it a whack with a hammer!!! that was 5 years ago!
