Hi all,
I'm new to this forum and hope a kind soul can help solve this annoying mystery. Apologies for the poor non technical description.
I recently bought an Apollo Woodpecker lathe (sadly without instructions), and was getting on fine, until the tailstock decided to disassemble itself.
I was trying to bore into some hard wood with a forstner bit in a chuck in the (MT2 taper) tailstock. However, the bit jammed in the workpiece, and when I pulled the tailstock back, the rotation of the bit & chuck unscrewed the taper from the (?) arbor? - the bit it should attach to, that has the handwheel at its other end.
I removed the handwheel and have extracted the "arbor"(?), which is part-threaded. It seems blindingly obvious that the taper and arbor should just screw back together - but they won't, and I've tried both directions! One way they'll screw together (by hand) a fraction of a turn and then jam, and I'm not tempted the use tools to force them together - in
the other direction they just don't 'catch'
I've attached a picture of the two pieces. So: can anyone please advise how I can fit these two pieces together?
Many thanks in advance,
Gerry
Gerry
