Hi folks , what is the easiest way to turn something 130mm long x 25mm dia with a 12mm hole running the length , ps I don't have a four jaw chuck just in case this is required , thanks for looking , Tony
bogmonster":5vexl01q said:Assuming you have some kind of chuck, screw will do, or a faceplate at a push....
Drill stock in drill press. Mount scrap to screwchuck / faceplate. Turn a short round cylinder about 20mm in diameter with a spigot just under 12mm to center stock. Use this as a friction drive. Use tail stock with live center at the other end. Could use some glue if you can cut the cylinder down to length a bit when finished but should not be required. You can turn pen barrels this way as well
I think that is what I would do but to be honest I hardly ever spindle turn so there may be a much easier way.
BM
bogmonster":1jpgx3sm said:Chas, your approach is practically the same except your friction drive is turned with drive centre, not screw chuck.
and screwing blanks to a face plate and mounting a screw centre would be just as long a task as basic spindle turning.tony":1jpgx3sm said:.. ps I don't have a four jaw chuck just in case this is required , thanks for looking , Tony
Spindle":2j554s3n said:Hi
I'd go about it in a similar fashion to Chas but I'd spindle turn plugs to fit both ends like this:
Easier to part the final item to exact length if you use two plugs
If you err on the slightly small side you can always take up the slack with a layer of tissue.
Regards Mick
bogmonster":3id2snra said:Oh well, I tried. Appears I make hard work of everything I do on the lathe. Glad This is just a hobby for me. Chas, your approach is practically the same except your friction drive is turned with drive centre, not screw chuck.BM
