xy mosian
Hi all, I am on the verge of making a stool similar to the one shown.
Just in case the dimensions are not readable. The top/seat is 330mm x 220mm. with a thickness of 30mm. Height is 334mm. My problem is the distance of the leg holes from the edges of the top. As shown the legs are 35mm from each edge. Are these dimensions enough? The top is Oak and the legs will be Oak or Ash. The tenons will be tapered with the small diameter at about 18mm.
Thanks in advance xy.
