hudsonhenry
New member
Hi I'm new to his forum and I am hoping that there is someone here who can help me.
I am building some MDF cabinets for my living room which I would like to spray paint. The cabinets have been sealed with two coats of MDF sealer and then primed with an oil based primer. I plan to use Dulux satinwood paint applies with an air fed HVLP gun.
My question is this: How long should I leave between coats? If I was brush painting I would follow the instructions and leave 16 hours between coats but if I spray thin coats will it be ok to put the next coat on once the proceeding coat is touch dry? My only experience of spraying is with 2 pack car paints, with which its 10 mins at the most between coats then a blast in the oven.
Any help or advice would be much appreciated
Hudson[/i]
Hudson[/i]
