Help - need to get sticky backing off facings
JonnyW
19 Jun 2015
Lerwick
A few years ago when my son was born, to keep light out his room to help him sleep, we used a Velcro blind that we stuck onto Velcro strips (hooks) that were stuck onto the facings around his window.
A good solution at the time as here in Shetland during the summer, it never gets dark!!!
The thing is not used now, so I removed the sticky Velcro strips off the facings. Well the strips came off, but the gum/glue backing didn't.
What an absolute nightmare to try and get off. I've tried everything I could think off: White spirit, nail varnish remover etc etc. All failed to dissolve the gum.
Any idea guys? I thought about nitromors! And then a little varnish. Horrible stuff though.
Jonny
Tried WD40? Meant to be a very good adhesive releasant.
This is what I used to remove the mess left An over exuberant Policeman decided 'Er indoors drivers window was"Tinted" too dark, without a light meter, and after I'd got the MOT Man to check it over with his, for this very reason.
Link below, It may "Chip" off when dry, or, as mentioned a softener is better.
Regards Rodders
http://www.toolandfix.com/stanley-0-28- ... Avf88P8HAQ
I use coconut oil to get gum residue off LP sleeves from old stickers...might be worth a go?
Also heat from a hairdryer to soften it will often help.
Thanks for the replies chaps. Will try all of the above.
Thanks again. Really appreciated.
Jonny
