Help...Circular saw blade
Webby
14 Jan 2012
Gloucester
have been trying to find a circular saw blade to fit my hand held circular saw
dimensions 190mm od x thickness 2.5mm and about 40 teeth but with a bore of 24mm
the bore seems to be the stumbling block
as any one any ideas please where i may obtain ...have been googling like mad lol to no avail
thanks in anticipation of a result
Dave
B&Q Performance Powersaw .....have to say some years old but still going strong just need new blade
Did not know that you could fit spacers so now i look for a spacer 24mm to 30mm so i can get blade with a 30mm inside diameter
have had a browse at screwfix catalogue cant see one there.......... spacer that is
so the quest continues lol
Reducing bushes are available but....
you need to make sure the thickness of the bush is thinner than the plate of the blade. otherwise the locknut will clamp only on the bush....blade will spin.
I may be able to get 1.8 mm thick ones but not sure what thickness the plate may be on any blade you get.
All the blades I can supply have 1.6 mm plate thickness.
I can get 30 teeth with 20 mm bore and have it opened out to 24 mm.
