I am stuck with this problem - I've not had this happen before with my old bandsaw...
I got a really old Startrite 3 wheel bandsaw a while ago and it's been running ok with the first blade I used (6tpi 1/2" Premium from Ian) which was a half inch though it did come off a couple of times put down to the blade stretching. I had it tracking in the center of the wheel and seemed to run pretty straight when the blade was in the center.
I have swapped the blade today as I want to do some finer cutting and I can't get the blade to track properly - it's a 14tpi 3/8” SuperTuff Carbon from Ian. I've not used this thin a blade before.
What's happening is I set up the blade in the center of all 3 wheels and I've set the tracking on the top wheel so it's straight ie no bias to either front or back.
When I turn the top wheel by hand to check the tracking the blade moves to the front of the wheels. If I turn the wheel the opposite direction ie backwards or anti-clockwise, it moves back to center and then to the back of the wheels. This happens the same on all 3 wheels so the tracking of the lower wheels must be ok.
If I turn the tracking knob it doesn't move the blade so I turn it more, and more and then suddenly the blade is at the back of the wheels. The same happens if I do the opposite where it moves to the front.
I've tried adjusting the tension more and less but it's still doing the same thing.
Any ideas? I'm stumped.
