Hanger bolt? Mounting 1/4" threaded Sonos bookshelf speaker
gidon
19 Mar 2003
West Dartmoor, Devon, UK
I'm looking for a cheaper way to mount the Sonos Play:3 speakers we sell which come with a 1/4 threaded mount hole. We can sell an special mount but it's expensive and I've seen in the US "hanger bolts" with a 1/4" bolt on one end and a screw thread on the other. But can't find them in the UK?
Anyone know where I could get them or another cheaper alternative?
Many thanks
Gidon
9fingers
26 Jul 2005
Romsey, Hampshire
The speaker will probably have a 1/4" UNC thread. The eBay screws
are most likely to be Whitworth threads which have a different flank angle
Some will fit ok but check before buying a big stock
Bob
xy mosian
21 Feb 2009
West Yorkshire
If the screw/bolt is in the wall... and the threaded hole is in the speaker cabinet.
Which one are you going to turn around?
Speaker or wall?
xy
Sorry couldn't find smlies, I was smiling.
Eric The Viking
19 Jan 2010
Following on from Bob's comment above, 1/4" and 3/8" Whitworth are both in common use in the entertainment industry - 1/4" Whit is camera (tripod) thread, and 3/8" Whit is European microphone stand thread (and for video cameras, portable lights and larger stills cameras too). Ironically, the Americans use a seriously odd thread for microphones*. As far as I know there is no metric thread for either mics or cameras in general use.
It's common for professional self-powered monitor speakers to have a 3/8" Whit threaded socket (sometimes two), so they can be mounted on mic stands. I've never seen one with a 1/4" socket, as it's not strong enough really.
I hesitate to ask, but if it's really 1/4" what is the socket intended for, or are these speakers really much smaller than they look?
Cheers,
E.
*5/8" 27TPI with 26TPI although I can't for the life of me remember which is for male and which for female use - basically both are nasty! This is the most common amateur thread though, largely thanks to Japanese and Taiwanese imports from the 1970s onwards.
m1ke_a
29 Jan 2012
Sussex
1/4 20 is a standard thread for cameras (3/8 16 for larger kit and tripods).
You'll be able to get connecting studs/ spigots / whatever from all sorts of photographic suppliers, and if you want to go OTT have a look at such places as Hagues
