chipmunk":vt2k8ps2 said:Hi Froggy,
You'll be extremely fortunate if that glue holds - No matter what glue you use end-grain to end-grain is perhaps the most difficult to join and a walking stick can get lots of stress in use.
I'd be tempted to try to drill it up the centre with a lamp auger (... if it's in one piece already, otherwise drill each block lengthways one at a time - although you'll need to make sure the ends of each block are square to the hole) and put a piece of 8mm steel rod or 8mm threaded rod up the centre. You may get away with aluminium rod if the weight is a concern.
Polyurethane glue will hold the rod in place if you rough-up the outside - unless you want to counter-drill the ends of the stick and use nuts on the end of threaded rod.
HTH
Jon
woodfarmer":1ly1e5i1 said:You can now fit either the handle plain or make a sword stick
