I'm looking to do a number of projects in my garden over the coming months - raised beds, decking and a climbing frame/slide/swing thing for my daughter. We want it all to look right together and like the look of "just wood" rather than stained/treated softwood, so I want to be able to make it all (or the visible bits at least) in the same hardwood. I've found somewhere that has a good stock of Oak that they're describing as "partly air dried" with a moisture content claimed to be 30% which they say is 1/2 that of green oak. Price seems to be about 30% higher than cheap treated softwood from my local timber merchant.
If I buy inch thick boards and use if for the surface of my deck over softwood joists, how stable will it be? I'm lookinag at 180x30x2400mm boards which I would plan to place over joists spaced at, say, 400mm, screwed down with a couple of screws into each joist. A bit of 'character' as the wood dries out will be welcomed, but I won't be popular if it rapidly looks like an earthquake has hit and, come Guy Fawkes night, the whole thing is fit only for the bonfire. Will thicker wood (e.g. go to 50mm thick deck boards) be more stable, or less, or make no difference?
For the climbing frame, I'm thinking of a basic "tower" structure made with 4" square posts with pegged m/t joints holding it together and platform, railings, ladders, etc. made with similar boards to the deck, or 50mm x 30mm sections. Is this likely to stand up to the combined effects of british weaher and the toddler test for years to come, or will I have some expensive hamster bedding by this time next year?
My mates at work think I'm mad and should buy kits or get someone to do it for me. What do you guys think? I'd rather have nothing than either of those... one way the garden won't look right, the other way we'll have to sell the house and live under the deck. What do you guys think? I'm methodical and careful, have helped out with a couple of "standard" decks in the past, and can call on the help of mates to do some of the grunt work and one or two much more experienced guys for occasional advice and assistance, but this will be the biggest job I have tackled myself by far... is this a decent project for some weekends and a bit of holiday over the next few months, or do I need to be thinking more of my grandchildren than my own daughter playing on this stuff?
Sorry it's such a long post! All advice (even if you tell me to forget it!) welcome.
