Not long brought one of the above second hand, I saw it running and it looked a bargin.
Got it home and gave it a bit of a clean up. It ran fine, turned it on for about the third time it would not pick up speed then it stopped. Found out it was a blowen fuse in the plug so I replaced it. switched it on the motor made a noise but would not turn after couple of seconds it blow another fuse.
I have now removed the drive belts from the motor so it has nothing to turn, the motor turns fine buy hand but will not run for more than 3-5 seconds when switched on.
I have gone through about 15 fuses trying to get it to work, all the wiring looks ok.
Can anybody help,
I do not want to take it back as I had to travel some distance to get it.
Thanks Paul.
Can anybody help,
Thanks Paul.
