PaulO
I recently purchased a Fobco Universal drill (like a Fobco Star but with the capability to perform "light milling duties"), an example can be seen here:
http://www.lathes.co.uk/fobco/
(half way down the page)
It runs beautifully, but has a bit of surface rust that I am sorting out. I have a couple of questions that someone may be able to help me with:
The down feed bar looks like it should be adjustable, but is seized on mine (there is some rust on the bar). I have tried to free it with a G clamp and a mallet, but to no avail. Can someone confirm that it should adjust before I heat it up with the oxy-acetylene.
The clamp for the table has a slit cut to allow the clamping bolt to pinch the main support shaft. On the table the slit does not go all the way through the casting, so the clamping requires a lot of effort. Should I complete the slit, or is some material left for a good reason. I could post a photo.
Does anybody now the procedure for fitting and correctly tensioning the quill return spring? I took mine out and it is a pipper to get back at the correct tension, although it is working for now.
Thanks for all your help.
