Floating shelf brackets (recommendations)
beaver
26 Dec 2009
ashford/kent
Hi Guys
As the title suggests im looking to fit some floating shelves, have any of you got any recommendations or preference's on make or type of brackets to use. the shelves will be 32-35mm oak in varying lengths up to about 1.8 mtrs, im not to concerned about price as given the weight of the oak without loading, quality is my first priority.
If you are going onto masonry the supports can be as simple as threaded rod fixed into holes in the wall with resin (like a resin anchor). The trick is to angle them up by a degree or two off the horizontal
