bertterbo
I want to drill a flat bottomed hole to accept a 608-2RS bearing, and then also a through hole for the 8mm center.
So 22mm OD, and 8mm ID. The flat bottomed hole would need to be about 7mm deep.
How would you do this with bright mild steel and only a floor standing drill press?
I'm assuming it's not really recommended and would be more of a milling operation?
