Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 74
The application isn't the gentle jewellery box lid catch at all, it's holding up a pivoting trap door in a tower scaffold plywood deck. These will have to pull really hard.
I've got some suitable magnets from Axy - 20mm diameter. A pair of these, with a steel keeper behind, and sticking to a clean steel plate will do it nicely - hold the trap open at 90 degrees for rigging the deck, but allowing it to release reasonably easily when it needs to close.
Because there needs to be a very strong pull (quite a lot of leverage is possible against the magnetic field), I need to set the magnets flush, probably into a block of hardwood. I can't have anything between the surface of the magnet and the steel plate they'll engage with. I guess if I did put them in blind holes, I could stack the magnets to increase the field strength, but I'd rather not if its avoidable.
Has anyone done this just by glueing them in with epoxy? Axminster sell some with countersunk holes through the middle to take screws or bolts: this would work but they are really expensive considering.
Any thoughts, anyone?
E.
E.
