the_g_ster
Hello,
Having had a neglected workshop for the last few years, I have gone about trying to make it spot on again.
One issue is that water has rotted the bottom on one of the panel doors. Given I am am a little time poor and the winter is coming I have cut the bottom off the door and treated the ends of the rails with wood preserver as the stile on the bottom was rotten as was the bottom of the rails. (all covered over with some plastic)
I now need to make a new bottom bit of door, and the panels are fine as saved them.
Issue is that I think the radius on the ovolo style panel bead is 7mm, and can't seem to see any on Wealden. The door is 40mm thick, B&Q from about 7 years ago, and standard panel style. Any ideas on how best to fix?
(Mental note to keep an eye on guttering as I think it broke on the snow and ice and then water was streaming down the door)
