Cheshirechappie
Lurking about somewhere in the back of my mind was the vague memory of having seen the following method of fitting a cap-iron to a plane blade, but I couldn't remember where I'd seen it. However, I've found it again, in 'Modern Practical Joinery' by George Ellis (pub.1902). His instructions are as follows.
"Having sharpened the back-iron to a fine edge on the oilstone, screw it fairly tight to the cutter, leaving about 1/16" [1.5mm] of the latter exposed. Next holding the pair very firmly on the bench, draw a hard bradawl, or the broken off end of a sawfile, along the edge of the back-iron; this will strip off a fine shaving of metal, and the operation should be repeated until it is impossible to see the slightest trace of light between the irons when the edge is held in a strong light, and the joint at the side, which is looked through, is shaded by the hand."
I can see this being a quick way of achieving a fit - if it works - but I wonder if there are any hidden downsides. Anybody tried this method?
