Allylearm
Installing a complete toilet ensemble from Wickes. The WC/Sink and "P" shaped bath are good enough. The bath screen and bath glass pane were reasonable. The only issue I had was the waste for the bath and "S" bends were cheap and after going to local PTS fitted new waste to bath, the sink already had a pop up plug on the taps. The Bath came with a chain and plug, I changed to pop up plug when changing the waste system, far better finish and no ugly chain being highly visable not to mention where to store it when not in use, the waste is at the front of the "P" Bath and glass panel sitting there did not give much room or taps to hang over as they are back corner.
So all in all a reasonable fix for a toilet that needed renovated, costing under £600 no labour. Why do they let themselves down in fitting's quality the only issue I had in the complete build as yet. Still to finish the WC so will see what the soft closing toilet seat has to offer in way of fitting and usability. The other issue is fitting the hidden waste in the WC never done one like that I usually have the waste in full view, but thought covering the dreaded cast iron waste pipe was a good thing. Time and fitting will tell.
To be continued.
To be continued.
