Afternoon all
I've got an acrylic bath to fit in the corner of a bathroom, which will be tiled.
I've been told that the proper way to do this is to fit the bath to the wall before tiling. This means that the bottom edge of the wall tiles sit on the top edge of the roll of the bath and are then sealed with silicon.
The bath is supplied with brackets which are screwed to the wall, like 'hooks'.
The edge of the roll of the bath is then dropped into the gap between the wall and the bracket to give lateral support.
The side of the bath is against a wall with a window, so the reveals will be tiled, meaning a fair bit of cutting and faffing about.
I don't fancy tiling with the bath in situ, but it seems that I've got three choices.
1) Fix the tiles to the wall starting just below the wall brackets and fit the brackets and the bath to the tiled wall.
2) Fit the bath temporarily and fix the second row of tiles at the right height. Remove the bath and tile everything but the lowest row. Then fit the bath, silicon it to the wall, fix the lowest row of tiles in the gap and silicon the gap between the tiles and the bath after filling it with water.
3) Fit the bath and struggle to fix the tiles with it in place.
Any advice will be welcome.
Dave
Dave
