Chems
Shadowfax is much more qualified and experienced to answer this than me, but the CO2 is a gas which means very small vapour particles and it disperse rapidly which means that its cooling effect is rapid but diss-appears quite quickly once in the atmosphere. But water when used effectively will have a huge surface area and hang in the air around the fire removing the heat rapidly which is of course one side of the fire triangle. Remove one side (heat, energy, oxygen) and you've won.
But once again in small scale if its just a motor thats burning and the power is off and of the above will probably do the job.
Its on the bigger scale that it comes to water, what we do as Firefighters when we enter a fire is we use our high pressure hose reels on a spray setting to fire off short blasts into the smoke layer in the room - not at the fire initially, this removes the heat extremely rapidly so much so that as it expands you will see the smoke almost expand out towards the head of the house (the branch) I'll have a look on youtube for the video they showed us on training.
Have a look at this one:
http://uk.youtube.com/watch?v=xmeEaW8dtCI
At about 3 minutes you can see the trainee using the "pulses into the smoke above the actual seat of the fire. The sound of breathing through the breathing sets really sets the adrenaline running for me.
But just remember, if its anything more than a few flames, run away its what I'd do if I was outside and its what all of you should do as well if you value your lives - doesn't matter how many lie nielson planes are going to burn.
