hunggaur
hi folks this may have been asnwered 100 times before and i am sorry if it has but i could not fined the answer in the search results.
i am looking to build a fitted unit out of MDF which will then be painted.
my problem is that when i have done this in the past the cut edges have always looked rough no matter how much i have sanded them. Is there a way of getting them as smooth as the top surface of the MDF.
i once heard that you should paint the edges with PVA then re sand with 600 grit is this true ????
any advise always welcomed
kind regards
jon
kind regards
jon
