EdK
Got a whole lot of skirting and architrave to fix.
Got delivered today and it's softwood (175mm ogee skirt / 63mm ogee architrave).
So far I've put knotting solution on the architraves and also used primer on them (only on the faces - not the back).
I've just started to do the same for the skirting but thought I'd ask what the best/most normal way of doing all this was....
My plan was to:
1 - knot
2 - prime (oil based)
3 - light rub down and glue any splinters / fill any holes.
4 - undercoat
5 - fix to the walls with screws and wooden plugs (two vertically every 600mm or so ?)
6 - paint with eggshell or gloss (probably eggshell as I find I'm not that good at gloss work)
Any help on this would be gratefully received !
Ed
My plan was to:
1 - knot
4 - undercoat
Ed
