Finish For Workbench
xraymtb
5 Nov 2007
What finish do people recommend for a workbench top made from pine?
I considered giving Osmo PolyX a go but it’s not cheap. Could go with BLO or Finishing Oil? I’m not a fan of the orangey look if I can avoid.
Cheap poly varnish stops glue getting stuck to it. Iron fillings getting into the grain etc. .
Cheers James
I like simple and easy maintenance, because it's just a bench that will probably get a plenty of beating. So, boiled linseed oil is good, maybe a couple of coats. It stops glue adhering, and although relatively easily damaged in use, also easily refreshed every now and then after, if required, either a bit of belt sanding or even some hand planing to level off again, plus maybe a bit of sanding after planing to to take out plane ripple. Slainte.
I don’t appear to have a surplus of much other than paste wax! I do have half a tin (maybe 200-250ml) of Colron Finishing Oil which I’ve had for about 10 years.
I can stop by Axminster in the morning and pick something up if I decide what.
