Hi James,
Thanks for the input on this. I am planning to have a closer look at the Midi and CTL26next week, a I do need a better Vac and these could be used for various tools. I have a 50L Clarke Woodworker extractor which I presently use for the Bandsaw, which works well, as with the P/T for the larger chips, but that still spews chippings around and possibly adding the Festool vac would sort that out, as well as when using the sanders, because the old HENRY I have needs to retire, like me as it's not good enough.
If I do go for the Festool Vac, I could always add that above the sanders to pick up stray dust, poosibly wih a bendy pipe and cowell which could help.
I don't have another filter other than the Microclean MC760, which I have on the bench when hand sanding, but had though of adding a ceiling/rafter air extractor of Microclean 1210/Jet AFS1000 or Record400, but it's all adding up money quickly to more than I had imagined to get the clean air I need.
I was hospitalised a wek ago with my Asthma, but now back to 90% and intend to take far more care on this issue even though it will cost a bit.
Do you find much difference in the power of the Midi and the ctl26 in pulling in the dust?
Not sure what you mean about taking out the plastic fins? Do you have a photo of that please?
Chers for now James
Alex
