External boiler - oil central heating - how much?
Rob_H
12 Feb 2005
Our boiler for our oil-fired central heating system is playing up - it's probably about 10-15 years old. I'd rather not shell out - just paid for a new bathroom, oil tank, sewage treatment system. Any ideas what a new external boiler for oil ch should cost? I just spoke to one company who quoted £3,500. About four years ago I paid about £1,000 in another cottage, so this seems a steep price rise and a half.
Hi Rob,
Depending on size, i wouldn't like to be paying more than £500 for a normal external 50/70 or 70/90 oil boiler plus the fitting charge.
Although i'm sure you could find a local plumber to do that for you at a reasonable cost (a days work at most)
HTH
Gary.
Rob..you don't say whether it is a standard boiler or a combi (but thinking it through given the age, it's not a combi). Is the existing boiler outside? If not then factor in the cost of extending the pipework. £3500 seems very steep to me.
Other factors to consider as to type of boiler is whether you have plastic CH pipework (doubt it, somehow) as there's limitations as to boiler manufacturer as some don't have the necessary protective measures to prevent overheating of the water and resultant failure of the plastic CH pipes.
The boiler is outside, standard not combi and the ch piping is not plastic. Apparently all boilers have to be condensing boilers now whatever that means.
Rob what exactly is the problem? oil fired boilers are not difficult to repair, if you could describe the symptoms I may well be able to help.
Regards,
Rich.
PM me if you'd rather.
it keeps locking out - every week or so, and it has to be reset. Sometimes it starts straight away, sometimes it won't start at all. Repairs/service are getting expensive.
Old or tired and dried out asbestos 'cord' around either the burner assembly or the access panel to the heat exchanger?
Dirty photocell?
Had both of these on our boiler which exhibited the same symptoms.
Rob the criteria here is the make and model of the burner, for instance, is it a RIELLO, or a NUWAY, or any other make, I have a feeling the solution is going to be quick and very cheap. :)
Rich.
We have a Camray boiler hung on the wall outside which is about 18 years old. Never had a problem with it, but we are going to change it next year.
The only viable alternatives are Worcester/Bosch condensing combi boilers, if you look around these are around £1400 -£2000 depending on size. if your boiler is like ours and not combi or condenser, you will see a reduction in oil consumption by 30%. As the current price of oil is about 50ppl there is quite a saving to be made over the lifetime.
We also have a Dunsley Highlander 5 multifuel, with all the wood I get at work and the couple of million square miles of woodland up here in the Highlands we use it all the time (except high Summer) its lovely and toasty :) SWMBO keeps the kettle on it too :lol:
busy builder":26wor2jl said:
.......you will see a reduction in oil consumption by 30%. .....:
Are you sure? We have a Worcester oil boiler about 15 years old. I went down the route of looking into fuel efficiency. I even contacted our oil supplier to get a printout as to how much oil we'd consumed over this period so that I had some hard facts. Figures taken off the web for an oil fired burner were around the 55% efficiency mark and so when I did the sums I got quite excited with the potential savings. The payback period looked really good.
Then I had my oil maintenance man actually tell me what my efficiency actually was. Nearer 80% and so suddenly the payback period got r..e..a..l..l..y long. Mind you, given the price of oil now, it bears looking at again.
I have a combi condensing boiler fuelled with LPG and I have no complaints, but BEWARE hard water areas. No problem with the C/H, but if your kettle furs rapidly so will the Hot Water heating circuit within the boiler.
Roy.
busy builder":37nccy2g said:
May beyour boiler is m0re efficient than mine, but a combi will save you money straight away as you are only heating what you need. On top of that are the benefis of the condensing system.
My knowledge of Boiler technology and CH systems is at least 30 years out of date but can you even get any benefit from fitting a condensing boiler to an existing old style system, surely the water temp management / bypass controls will not be in place to match the boiler.
It's for sure fitting a combi boiler would entail a whole new rework of the hot water/CH system and loose any airing cupboard/drying room facility an older property is likely to currently use.
The old boiler casing fitted in my property is not the most efficient by modern standards and has had new pump/burner fitted by me over the years but every time I sit down and try to work out the efficiency advantages versus the installation cost of a new (oil) boiler I come out with a 10+ year claw-back. Of course I may just be wrong in my understanding of modern technology.
No, Chas, I reckon you're spot on.
You say your boiler is 80% efficient ? is that 80% of your boilers efficiency ?
Run your boiler for another 10 years by all means but what will a new boiler cost you then ?
If you look at it this way, you have a 2 ltr petrol enging running at 80% efficiency and a VW PDi TD running at 80% which is the more economical ?
Its all a matter of how you look at life, do you replace your car often or are you running an 18 year old one ? if not why not ? I have a VW TDI which is 7 years old and will keep till its dropping to bits, but SWMBO would be on my back if the boiler was un reliable.
decisions decision
In the situation where you have an existing heating system complete with hot water cylinder and roof tank as I understand today's practice you would install a 'system' boiler which would enable you to retain both features.
The main contribution of a condensing boiler shows up when you look at the flue pipe. On a condensing boiler much more heat is extracted from the fuel, so much so that the flue pipe will probably be constructed of plastic rather than steel. The main advantage of combi boilers is their compactness, they are a complete package and thereby cut installation time.
Any system that is 30 years old would probably benefit from an improvement in controls whether the boiler is replaced or not.
Roy.
Roy.
Not mine (goes into smug mode) :D It's already the DB's.
The one change I would make if I could is to put in more insulation - everywhere. Having put in oodles of Kingspan into the renovation project, it's staggering to feel the improvement.
I still swear by(not at) the old Potterton BOA floor mounted atmospheric central heating boiler, easy to service and very efficient, and that's 30 years down the line, fast forward to today, the alternatives are wall mounted combis, okay if you are in rented property, but if you own the house you have to remember that the H/W heat exchanger is nothing more than a kettle, and we all know what happens to the inside of those(depending where you live, of course) introducing fresh cold water into a system and boiling it will produce limescale despite having a combimate softener in line, I know, I tried it, a complete waste of time if you live in Berkshire.
As for low water content condensing boilers, yes, they are efficient and fit very nicely into modern kitchens, that's where it ends, low content means a small heat exchanger, this will scale up eventually,(AS WILL ANY BOILER)
Boilers are not something that you replace on a regular basis, one gets the impression the the agenda is driven by the manufacturers jumping on the efficiency bandwagon in order to make a profit, that;s understandable as that's what drives industry and puts money in the directors pocket and keeps shareholders happy.
In short, Potterton boilers are still going strong today, it's a shame they don't produce them any more but you can understand why because it would take the manufacturer to long to get payback, which is why they only make things that will last for about 10 years at best.
Regards,
Rich.
Rich, it says it's a Thermocon boiler - no model or any other name. It's totally stopped now.
