Experimental steam bending (not quite going to plan) ....
edmund
13 May 2005
South Croydon, Surrey
Thought I'd share this for general amusement.
I'm in the process of making some drawers. I decided to use some oak I had left over for the sides, back and bottom which I cut to 8mm thick from a 2 inch board. Problem was that some of the finished pieces cupped quite a bit. So, ever the innovative experimenter I decided to see if I could steam bend them flat (as the pieces were quite small 8" x 4") by - wait for it - soaking the piece in water and putting in the microwave for a bit to heat the water up and then clamping the piece flat :D Reasonably sound theory I thought and worth a bash.
Trial no. 1 was quite tentative, but seemed to work. So trial no. 2 I put a couple of pieces in. However, I put the timer on for a bit too long. This I found out from the smoke and smell emanating from the microwave, suggested something was a bit overcooked :lol: There was a nice black ring at the end of one bit of wood profusely pouring out smoke (burning from the core of the wood) :shock: :lol: The rest of the wood has also gone a bit crunchy!
Anything that's now heated up in the microwave as an oak-smoked flavour to it!!
Vicissitudes of being a pioneer :lol:
Edmund,
Thanks for the pioneering work - perhaps we should strike a medal for those intrepid UKW members who advance the cause in such spectacular ways. I reckon if SWMBO has seen her microwave, then a Darwin award is a near certainty!
Edmund
for your trial #3 insert some long nails or screws into the middle of the wood this will help dry the core out much more quickly, oh and have a camera ready for the WIP images please.
Andy
Fortunately, as a sole agent my conversion of the kitchen into workshop no. 2 doesn't run the risk of anyones wrath (phew!).
Had considered using the microwave to make up my wax polishes: metal saucepan + turps + waxes + 3 mins on high power = flaming kitchen and no back door :lol: :shock:
But then thought better of it :lol: :lol:
dedee":zcly6o79 said:
for your trial #3 insert some long nails or screws into the middle of the wood this will help dry the core out much more quickly, oh and have a camera ready for the WIP images please.Andy
Presume that the more metal I put in the microwave the better the wood will dry... :lol: :lol: :wink:
If you put an egg or two in as well (in its shell) it will help draw the moisture out. :)
try putting in a light bulb (lamp for the electricians) to see if u can come up with some more bright ideas :lol: :lol:
shaun
I've just spent an hour on google trying to find a six foot wide microwave, it's no good I'll have to saw it into nine inch pieces first, cook it do the bending then glue it back together again. :)
