Euro Hinges for beginners - Part II
Niki
18 May 2006
Poland
Continued from part I
https://www.ukworkshop.co.uk/forums/view ... hp?t=36107
Regards
niki
Niki
came across this just as I was about to fit 10 inset cupboard doors. Have just done my first one following you're method and its spot on.
Thank you very much for taking the time to put this together, its made my life a whole lot easer.
Toby
Cheers Niki, I've got a load of kitchen cabinet doors to make and fit. This should make life much easier. Really good write up too.
Thank you so much everybody
I'm so glade that it can help some of you....
By the way, if the door is too big for the drill press and you don't have a drill Stand or in case of "Field emergency", you can drill the holes also with a hand drill...
Regards
niki
Shultzy":1vvrjxbs said:
BTW the Oal you mentioned is spelt Awl and pronounced "all", it took me a while to work out what you meant. :lol:
Thank you Shultzy
Ooooops, sorry....you see, how good it is that I attach pictures so even if the spelling is not correct, the picture will tell you....
Thank you for the correction
Regards
niki
