First off, there's not a chance I'd monkey around in there myself, we'll be getting a proper electrician in, so don't worry about that. I'll cheerfully replace sockets and switches, but I know my limits!
(I have a reasonable grasp of the principles of electricity itself, but from an entirely theoretical perspective, and with little practical-application-in-household-wiring grounding. If you'll excuse the pun.)
My girlfriend has recently bought an illuminated mirror for the bathroom, which she's been after for a while. (I suspect it's at least partly so she can appropriate the mirror that's currently in the bathroom to attach to the bedroom wall.) It arrived today, and I'm a bit wary about it. The ones I've seen before in showrooms have generally had a plastic box around the back of the mirror itself - and since I basically think of the bathroom as 'outside' for all DIY intents and purposes, I've been imagining these as rubber-gasket-sealed waterproof boxes like you'd see on external lights. This thing, on the other hand, has one sealed box at the back which the power cable runs into, which then sprouts cables that run to four fluoro tubes around the outside of the unit, completely exposed.
Aesthetically it's not too much of a problem, as it happens, as one would have to stand right in the corner of the bathroom behind the door to be able to see much of the back of the thing once it's installed (the company markets them as 'ambient wall lighting' or something...), but I'm a bit concerned at what is essentially exposed electrical connections in a regularly-steam-filled room. Am I just being paranoid?
