Electric light switch question
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
Just wondering if anyone can help, I need to replace this light switch/fan fuse spur as the light switch is faulty.
I‘ve been Googling & can find a white plastic one but not one in brass, does anyone know where I can source one, cheers
The brass is just a faceplate by the looks of it. the interior looks a lot like some of the old MK stuff (before they went to the individual 1 unit clip in modular ones.
is there a makers name inside? looks unusual as the three modules are completely surrounded by the white border, whereas I would expect to see a broken border. so as smackie says it might be a brass faceplate/cover. does the new one have to be brass?
this range might do to swap with
https://www.click4electrics.co.uk/d...single-plate-3-gang-aperture-dpbr403wh-p-4275
https://www.click4electrics.co.uk/p...n-polar-white-13a-dp-fan-switch-module-p-5838
dam cant find a fuse module. is the fuse for the fan? edit found one
https://www.google.co.uk/url?sa=t&r...e-unit-white&usg=AOvVaw2ZLaIsVJU4yurty4LhngiH
https://www.click4electrics.co.uk/p...d002pw-polar-white-2-way-switch-module-p-5168
this company sells the faceplates and the modules in brass if you want the switches to match the plate
https://www.electricalcounter.co.uk/
